Highlighted
Re: Refrigerator auto fill water pitcher is leaking from the front. No solutions found.
JUMP TO SOLUTION
Same problem here.
Highlighted
refrigerator auto fill pitcher
JUMP TO SOLUTION
I purchased a new refrigerator in July and since the purchase, the auto water fill pitcher has leaked under the spout.  I have cleaned, reseated, etc...several times and nothing has helped.    It is a mess anytime anyone uses it!  HELP!
Highlighted
Re: refrigerator auto fill pitcher
JUMP TO SOLUTION
Do you hand wash or use a dishwasher to clean your pitcher?
Highlighted
JUMP TO SOLUTION
Hand wash only
Highlighted
JUMP TO SOLUTION
You can clearly see, where the container itself, right under the spout where it meets the seal, that the container has a very slight protusion.  Obviously a manufacturing flaw, that prevents the seal to be tight.  I will be more than happy to provide a photograph to an email address.
Highlighted
JUMP TO SOLUTION
That was going to be my next request lol Smiley Happy Please provide the photo of the leaking pitcher as well as the full model and serial number here: http://bit.ly/2sSxapD
Highlighted
JUMP TO SOLUTION
Al, just making sure that you received my information yesterday.  Thank you so much for your assistance.
Highlighted
Re: Refrigerator auto-fill water pitcher leaks
JUMP TO SOLUTION
My pitcher leaks too. Frig is about 8 months old. Very annoying. Have to pour over the sink.
Highlighted
JUMP TO SOLUTION
There is a fix for this...remove the gasket and put a rubber band where the gasket sits and then put the gasket over the rubber band. This makes the gasket thicker and seems to work for me.
Highlighted
JUMP TO SOLUTION
So, this is it.  Write a complaint and get no response.  Its's not that hard to create a seal on a pitcher.  Makes me think we made a mistake when purchasing a Samsung that relies on perfect seals to operate a fridge.
