Highlighted
Refrigerator door seal doesn't always seal between the 2 doors
JUMP TO SOLUTION
The door seal does not always rotate when doors are closed. The top of the hinged seal does not engage the fixture that causes rotation. I can push the seal up and it will engage. But, eventually it slides back down. How to fix this permanently?
1 SOLUTION
Highlighted
Re: Refrigerator door seal doesn't always seal between the 2 doors
JUMP TO SOLUTION
Have had unit for years. Yes, it is level
 Found Mcgiver fix. Unscrewed rotator block at top of seal. Inserted a toothpick. This lowered the block just a little. Now seal rotates reliably, I hope.
2 REPLIES 2
Highlighted
JUMP TO SOLUTION
How long have you had this unit? Can you verify that the unit is leveled? https://www.samsung.com/us/support/answer/ANS00062321/
Highlighted
JUMP TO SOLUTION
