10-04-2020 01:39 PM
When I set a temperature for either the fridge or the freezer side, how do I know when those temperatures have actually been reached in the unit?
Solved! Go to Solution.
10-07-2020 04:00 PM
Try the following:
If the above troubleshooting steps didn't help, here are some service options:
- If your unit was recently purchased, you can check with your retailer on their return/exchange processes.
- If you have an extended warranty you can reach out to them to have service processed.
- If you're within the one year warranty, you can Private message one of our moderators to have service processed. http://bit.ly/33ipYnO
- If you're OUT of warranty, you the following link to locate a service center in your area by using
the link below
http://www.samsung.com/us/support/service/location
10-06-2020 04:58 PM
Could you please provide the model number for the refrigerator?
10-07-2020 06:09 AM
Model # RF24R7201SR
I bought two third-party fridge and freezer thermometers, and they have been in the unit overnight. Here are the readings compared to the temperatures I had set:
Fridge: Set 36, reads 38
Freezer: Set -2, reads +2
Thanks.
10-07-2020 06:25 AM
How often are you checking the thermometers?
10-07-2020 01:27 PM
Checked thermometers for the first time after they had been in place overnight. Just checked them again 7 hours later:
Fridge: Set 36, reads 40
Freezer: Set -2, reads -1
But the intent of my question was really about determining interior temps WITHOUT the use of third-party thermometers. Apparently they are necessary. One would think that at this price point Samsung would have integrated well calibrated thermometers, so that the user could be assured that temperatures set were temperatures met.
10-07-2020 04:00 PM
Try the following:
the link below
