Refrigerator ice maker problems
(Topic created on: 1/27/21 6:06 AM)
user2qRji3C2AX
Kitchen and Family Hub
Model #RSG257AARS refrigerator will only make ice after pressing the test\reset button. The water dispenser works fine. When problem first started I changed the water filter and all was well. A week or two later the same problem is back.
1 Reply
SamsungBri
The next step would be to proceed with service. You can use the following link below to request service or contact our phone support line at 1-800-Samsung to have service set up for you: https://www.samsung.com/us/support/service/
