user8wGAFGSMbr
Refrigerator not making ice
JUMP TO SOLUTION
I bought my refrigerator 2 days ago. It was plugged in and set the freezer to 0 degrees.  32 hours later no ice has been made. Last night I set it -1 degrees and hit the reset button. Approximately 10 ours later, there's still no ice made. My water comes out fine so I'm assuming it's not the water line. Any suggestions?
1 SOLUTION
user8wGAFGSMbr
Re: Refrigerator not making ice
JUMP TO SOLUTION
So....after a week of waiting for the technician to come out (and no ice) this morning ice came out. I didnt touch the refrigerator this entire week. The only thing I have done that has anything to do with water is the house sprinklers. Two of my sprinkerlers were kicked off and the pressure of the sprinklers were bad. Yesterday I fixed the sprinklers and the pressure was good. This morning there was ice! I dont know if that was the problem or not....but the technician didnt find a problem.
7 REPLIES 7
Honored Contributor
JUMP TO SOLUTION
@user8wGAFGSMbr Sorry to hear, can I ask if the unit was installed professionally? If so, have you spoken with them to have them come evaluate the installation? Also, can you provide the model code of the fridge?
user8wGAFGSMbr
JUMP TO SOLUTION
Yes it was installed professionally. I have not called them yet, I was hoping it would be an easy fix. RF263BEAESR/AA.
Honored Contributor
JUMP TO SOLUTION
I certainly understand, here are some troubleshooting steps that might help: http://www.samsung.com/us/support/troubleshooting/TSG01001027/
user8wGAFGSMbr
JUMP TO SOLUTION
The freezer is working fine and the fridge is working fine. Ice is not being produced.
Honored Contributor
JUMP TO SOLUTION
Here's a link to more specific steps regarding the Ice Maker: http://www.samsung.com/us/support/troubleshooting/TSG01001012/
If these steps do not help, my next recommendation would be to have a service technician out to evaluate. Samsung covers this under the limited warranty. You may also have other options through your retailer though.
user8wGAFGSMbr
JUMP TO SOLUTION
I called and will be getting a technician out. I'll see if they're able to fix the issue. If they do I'll post it.
user8wGAFGSMbr
JUMP TO SOLUTION
