- Mute
- Email to a Friend
01-25-2021 10:39 AM in
Kitchen and Family HubGood afternoon-I purchased new Samsung refrigerator in July 2020 at our Home Depot and since then the water pitcher has leaked. How may I obtain a replacement pitcher? I purchased the protection plan for this appliance as well. Thank you!
Solved! Go to Solution.
- Mute
- Email to a Friend
01-25-2021 10:49 AM in
Kitchen and Family HubHey, give this link a shot: https://www.samsung.com/us/support/troubleshooting/TSG01001852/ If this does not help I recommend letting a service technician have a look. Send your full model code and serial number via private message to get started.
- Mute
- Email to a Friend
- Mute
- Email to a Friend
3 weeks ago
(Last edited
3 weeks ago
by
SamsungLarryK
) in
I purchased a bag of various sizes and lengths of rubber bands from (STAPLES). I inserted a small rubber band under the rubber gasket on the lid. I gently rocked the lid from side to side until the lid was closed. Make sure the gasket and rubber band are flat. My pitcher has not leaked since June 1st, 2020. I have received many responses from individuals saying this fix has worked for them. Good luck and stay well.
my <Hidden>
