Highlighted
Rf217ACBP Fridge won't display temp
JUMP TO SOLUTION
My Rf217acbp panel only shows one bit indicating it's on but won't respond to any button. It does remain cold and continues to function normally but I can't change any of the settings. Ice doesn't work.
Tried leaving it off for about an hour to no avail. Removed any ice blocking the holes at the back wall. Panel remains showing the one bit digit.
1 SOLUTION
Highlighted
Re: Rf217ACBP Fridge won't display temp
JUMP TO SOLUTION
Try holding  Power Freeze + Power Cool down at the same exact time for about 8-12 seconds.
5 REPLIES 5
Highlighted
JUMP TO SOLUTION
Hello there, what is the "one bit digit" that is showing? Can you provide a photo of it?
Highlighted
JUMP TO SOLUTION
That's blue digit just blinks and blinks.
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
This solved the issue. Much appreciated!
Highlighted
JUMP TO SOLUTION
Are you still needing assistance?
