Highlighted
Rf263teaesg leaking under corner of freezer door
Wondering if anyone has had same problem.  Turned off ice maker and water line.  Very frustrating.  My floor is warping bc of this.  Have only had fridge two years.
2 REPLIES 2
Highlighted
Re: Rf263teaesg leaking under corner of freezer door
I'm sorry to hear that, can you send me a private message with your full serial number and pictures of your floor?
Highlighted
Yer I have exactly the same problem every time the freezer refills with water loads pours all over the floor near the bottom left floor hinge, and alongside that I hav enever been able to get the temperature in the freezer below -6 and its not even 2 years old yet
