Highlighted
Ring Doorbell not woring properly.
After the recent Samsung family hub software update, my ring doorbell camera view stopped working. When someone press Ring Doorbell, nothing happen on family hub. I did factory reset, but still same...
6 REPLIES 6
Highlighted
Re: Ring Doorbell not woring properly.
I have the same problem, shows network problem.  tried reset, clear cache etc with no help
Highlighted
I'm sorry to hear that, have you tried to re-sync the app to the ring alarm? Also, have you made sure that everything is connected to the same wi-fi?
Highlighted
This is happening to me also. What's the solution?
Highlighted
Samsung service tech came to my home a few days ago. He said there is no trouble code. Nothing wrong with the refrigerator. He recommended uninstalling Ring app. I was really disappointed with Samsung. The after service assistant to the customer is terrible. I tried everything I can do. Still same problem....
Highlighted
We are working on an update to the app, to fix this issue.
It should be available as soon as the fix is verified.
Highlighted
Please check with app update 4.1.24 for Ring. Please restart lcd panrl after the app update.
