Highlighted
Samsung Dishwasher Auto Release door not working
I have a Samsung - Linear Wash 24" dishwasher model # DW80R9950US. It was purchased March 2020 and i've noticed over the last month the door does not open as far as it used to for the Auto release drying. It's gotten to the point where it's not drying as effectively as it used to. Wondering if there's a part I can lubricate or anything I might be able to do to fix this. Thanks.
3 REPLIES 3
Highlighted
Re: Samsung Dishwasher Auto Release door not working
Does it show any error codes?
Highlighted
No, the dishwasher isn't showing any type of error. To be more specific, the door pops open, it just doesn't open as far as it used to, and as a result less of the moisture is able to exit the dishwasher. I don't think this is an electrical issue. It seems more just mechanical with the door hinge.
Highlighted
How long have you had the unit? Can you check around the latch of the door to see if anything could be damaged or blocking the door from closing?
