user6UmngSqHuO
Samsung Dishwasher DW80J7550UG Whining Noise
JUMP TO SOLUTION
My dishwasher is only 18 months old, so is now out of warranty. This sound occurs at cycle start up, the goes away after about 1 minute. It then reoccurs about 2-3 more times throughout the cycle. This video is taken from the base of the unit at the bottom of the door. Sounds like it is coming from the base area where the pump would be, but I can't be certain. Any thoughts on what this is and what part may need to be replaced? Thanks.
https://youtu.be/P64lC7HJ55E
1 SOLUTION
user6UmngSqHuO
Re: Samsung Dishwasher DW80J7550UG Whining Noise
JUMP TO SOLUTION
Thanks for the quick reply. I just removed the drain filter assembly components and did find a toothpick that somehow made its way through down to the drain port. Quickly tested it by starting a new cycle and did not hear the sound. Will give a full cycle a try tonight to validate.
EDIT: CONFIRMED, THIS FIXED THE ISSUE. THE TOOTHPICK MUST HAVE BEEN BLOCKING THE MECANISM AT THE BOTTOM OF THE DRAIN.
8 REPLIES 8
JUMP TO SOLUTION
Give this link a look through. It should help.
user6UmngSqHuO
JUMP TO SOLUTION
JUMP TO SOLUTION
Great! Please keep us posted.
user6UmngSqHuO
JUMP TO SOLUTION
Yep, worked great so I'm all set, Thanks again for the help.
JUMP TO SOLUTION
Thank you for posting!
user2RB0DUvAGA
JUMP TO SOLUTION
I have same problem and tried to watch video and go through link but cant see anything
In essence i have a new dishwasher and it makes a whining sound when water is filling
Then it goes away until the water starts again
Can someone help
pabmarc@gmail.com
Paul
JUMP TO SOLUTION
@user2RB0DUvAGA, for assistance with this concern, please send us a private message to the link with your model number and the serial number?
userlrnuDn42uW
JUMP TO SOLUTION
Samsung Dishwasher DW80J7550UG making a Whining Noise
Me too   My dishwasher is only about 18 months old. This whining sound occurs at cycle start up, the goes away after about 1 minute. It then reoccurs about 2-3 more times throughout the cycle. Sounds like it is coming from the base area where the water wall is or pump would be. What solution was given to others ? I can't locate the solution receomended. Thank you
