Samsung Family Hub refrigerator profile setup
(Topic created: 11-30-2021 09:41 AM)
usersjACz8or3L
Kitchen and Family Hub
Hi, I just purchased my Samsung Family hub refrigerator on 11/302021 and I can't set up profiles for my family, I follow the steps go to settings but I don't have "profiles" option under settings. Please help
MsBri1
Neutron Star
Hello, I apologize for the inconvenience at this time it appears the Animation, illustration, and family board themes have been deleted; default themes will reset to the Weather theme. I located this article that will explain all the changes here if needed-
https://us.community.samsung.com/t5/Kitchen-and-Family-Hub/Family-hub-6-0-software-update/td-p/18522...
1 Reply
MsBri1
Neutron Star
