userWuSNEksnIi
Samsung Gas Oven won’t heat past 175
JUMP TO SOLUTION
My oven is barely a year old and now won't heat up. We let is sit for 45 minutes and nothing happened. Really disappointed that this range cost so much and failed already. Anyone have any advice on this?
1 SOLUTION
Re: Samsung Gas Oven won’t heat past 175
JUMP TO SOLUTION
If you have tried resetting the breaker for 10 minutes and the symptom persists, it will require service.
Please send us a private message with the full model code and serial number:
7 REPLIES 7
JUMP TO SOLUTION
Have you seen any error messages?  Have you attempted to reset the unit?  Could you provide the full model of the oven?
userWuSNEksnIi
JUMP TO SOLUTION
@SamsungJam Should have put that info in the first message, applogies. We did not receive any error messages and we have reset the unit. The top burners work fine and ignitors resistance seems to be within range. Registering 1400 ohms. The full model number is NX58M6630S.(might be the letter O, not the number zero, hard to tell.) Thank you for any help
JUMP TO SOLUTION
userWuSNEksnIi
JUMP TO SOLUTION
Thanks! I realized after I replied earlier it is actually in warranty.  Waiting for a repair guy to call.
userDIlpvVxfNe
JUMP TO SOLUTION
model #FE710DRS
samsung
cuts off at 150 degrees
JUMP TO SOLUTION
Can I have your serial number via private message?
userWDShjpLVGB
Thank you for the information. I won't be buying any of S...
JUMP TO SOLUTION
Thank you for the information. I won't be buying any of Samsung's stoves anytime soon.
