Samsung Microwave oven Fan runs on its own
(Topic created on: 3/30/21 7:07 AM)
usertKrYiHxrCK
Kitchen and Family Hub
We have a Samsung Microwave Model ME21M706BAS , the fan will start on its own when the microwave has not been used for over 8 hours, it also will set up to run for 7 seconds but you need to hit start. this has been going on for over two months,  Can this be fixed or do i just buy another microwave.
Glenn
1 Reply
SamsungTam
Hello, I do apologize for the inconvenience this has caused. How long have you had the unit? When the fans run on its own does the plate on the inside turn as well?
