userfiFCdywxdz
Samsung Oven will not broil or heat
JUMP TO SOLUTION
I purchased a fancy Samsung slide-in range last March 2018.  The first issue was that if you barely touch the knobs the burners come on.  I was willing to look past that.  Also, the unit is supposed to connect to wifi for use with a phone app.  That NEVER worked, but I didn't worry about it since it was a feature we were probably not going to use.  Today?  The oven won't work at all.  The top burners wok fine, but the oven will not bake or broil.  The igniter in the oven will not glow.  The range was bought new at Best Buy.  The model is NX58M9420SS.  Has anyone had this problem?  I had a Samsung washing machine that was recalled and a Samsung microwave has a roaring sound whenever you turn it on.  This is it with Samsung for me.  In the meantime, my 85 year old mother doesn't have an oven to use.
1 SOLUTION
Re: Samsung Oven will not broil or heat
JUMP TO SOLUTION
You have to make sure to respond in the community directly and not to the notification e-mail.  Could you send a private message with your serial number? http://bit.ly/2ihPL97
6 REPLIES 6
JUMP TO SOLUTION
If you turn on one of the burners, are you able to turn on the oven?
userfiFCdywxdz
JUMP TO SOLUTION
The surface burners work.  Nothing inside the oven works.  No baking.  No broiling.
JUMP TO SOLUTION
I understand. Thank you for confirming. Will you please send a private message with the serial number so I can look into this further? http://bit.ly/2XERsky
userfiFCdywxdz
JUMP TO SOLUTION
I sent you a message in June and STILL haven't heard back from you.  The stove STILL doesn't work.
JUMP TO SOLUTION
userfiFCdywxdz
JUMP TO SOLUTION
Latest update.  Samsung provided a one-time extension of my warranty to allow for the repair of my range that I bought in 2018!  They came out within 48 hours and repaired my oven.  Thanks!
