Highlighted
Samsung RF28R7351SG french door fridge missing tray in freezer door?
I recently acquired a used RF28R7351SG refrigerator and looks like on the freezer door, where the upper sliding tray is located, there is a mount on the door for a small bin/tray but it is missing.  I went to Lowes and HomeDepot to check and the display models there have the tray either but the owners manual mentions taking that tray off in order to remove the freezer basket.
Anyone else out there with the same fridge can tell me whether you have that bin or not?  If you do have the bin, can you look to see if there is a part number so I can try to look for it?  Thanks
