Samsung RS261MDRS Digitial Display Some lights won't turn on
(Topic created: 08-22-2021 02:40 PM)
userMpbv4x7Ph6
Kitchen and Family Hub
I have the Samsung RS261MDRS. The "Ice Off" and "Cubed Ice" LED indicator lights won't turn on when selected. The options work, and I can hear the chime sign when changing selection, but whether selected or not, their indicator light is off.
What might I be able to do to fix this issue? Everything is working , but I can't tell if the ice maker is on or off unless I press the button  and listen for the distinctive on/off sounds.
Do I need to replace some kind of circuit board?
1 Reply
SamsungStephanie
Hello, I would recommend a technician servicing the unit to obtain an accurate diagnostic. However if you would like to service the refrigerator yourself please contact our parts department J&J international to purchase a service manual at 1-800-627-4368 before proceeding. I apologize for any inconvenience.
