usera9ddaA4Y45
Samsung RS261MDRS beeps 11 times every 2 minutes (door alarm?)
JUMP TO SOLUTION
I have called Samsung Support twice now to troubleshoot my issues with my refrigerator.
The refrigerator is beeping 11 times every 2 minutes. The manual states that one of the features is "Door Alarm Beep sound reminds you the door is open." However, there is no alarm icon on the control panel to disable the alarm, like most models seem to have (based on my online research).
The door is closed and there seems to be no damage or issue with the magnetic seals for the door. The support reps that I spoke with said that there is no known way to disable the alarm, but I feel that someone somewhere must have had this same issue.
Any help with this issue is GREATLY APPRECIATED. Everyone in our house is about to go crazy with the continuous beeping.
1 SOLUTION
Re: Samsung RS261MDRS beeps 11 times every 2 minutes (door alarm?)
JUMP TO SOLUTION
No problem! When was the unit purchased?
9 REPLIES 9
JUMP TO SOLUTION
It sounds like a sensor may be going bad. Have you tried unplugging the unit for 10 minutes?
usera9ddaA4Y45
JUMP TO SOLUTION
Yes, that was my fear as well. I have tried unplugging the fridge and that has not worked. :/
Thanks for your reply!
JUMP TO SOLUTION
usera9ddaA4Y45
JUMP TO SOLUTION
2014, I think.
JUMP TO SOLUTION
You can find a repair center using the following link:  Link
userlK7xn30wbF
JUMP TO SOLUTION
Hi. I wanted to ask if you solved the beeping problem?
userL7Ha0hTLaP
JUMP TO SOLUTION
How did you solve it?
I am having the same problem.
Thank you.
userlK7xn30wbF
JUMP TO SOLUTION
Hi. I’m having the same problem. .. does anyone know what causes it?
userlK7xn30wbF
JUMP TO SOLUTION
Did you solved the issue?
