Samsung Range Auto Clean not working
(Topic created on: 1/21/21 9:58 AM)
userEv93or6iWs
Kitchen and Family Hub
had a problem with the numbers like running around so had best buy come fix and now the self cleaning will not clean for the 2/3/5 hours only will clean for 2/3/5 minutes and they can again to fix put another part in and still will not clean for the hours stated in book
1 Reply
SamsungCaleb
I'm sorry to hear that, how long have you had this range? Also when trying to use auto clean does it give any kind of error code when it stops working?
