Samsung Range (NX60T8711SS) burner indicator light dead
(Topic created: 09-09-2022 02:26 PM)
redrocklobster
Kitchen and Family Hub
This range has a blue light ring around the burner knob when the burner is on.  On the front right burner -- the power burner I use most often -- the light started flickering for a while and now is pretty much completely not working.
Is it likely to be a bulb?
(edit: seems unlikely to be bulb because it will momentarily light up at full brightness periodically, as in when first igniting burner. more likely some switch?)
Can it be replaced by user and if so how?
