userGUCQcDKUFm
Samsung Refrigerator RF23J9011SR consistent humming noise
JUMP TO SOLUTION
Hello, I have a Samsung RF23J9011SR refrigerator I purchased from home depot about 2 years ago. It consistently makes a noticable humming noise throughout the day. It does go off, but returns every 10-15 minutes. I turned off the ice maked using the panel control, and the noise persists. Additionally, I cut the power to the fridge (naturally the noise went away), waited 15 minutes, then turned the power back on. After about 10 minutes, the humming noise returned.
This has been going on for quite some time - 6 months or more.
Any idea what can be causing this and what can be done to fix it?
Thank you,
Dan
1 SOLUTION
Re: Samsung Refrigerator RF23J9011SR consistent humming noise
JUMP TO SOLUTION
Hey, give this link and this link a shot. They should help.
3 REPLIES 3
JUMP TO SOLUTION
userGUCQcDKUFm
JUMP TO SOLUTION
Larry,
Sorry for the late reply. I just got to this now amd, yes!!!, it seems to have fixed the issue.
Thank you so much for your help!
Dan
JUMP TO SOLUTION
We're glad that you're up and running!
