userLYRMGXdZZu
Samsung dishwasher DW80K5050US / does not power on
I have a 14 month old dishwasher hardly used and no longer turns on.  It died in the middle of a cycle.  water is still inside and will not drain as well.  Please help.
88 REPLIES 88
Not applicable
Re: Samsung dishwasher DW80K5050US / does not power on
I would be happy to look into this further. Can you please send a private message here: http://bit.ly/2Kq3B5F with the full serial number of the dishwasher?
JonathanYu
Hi I ran into the same problem. Washer died in the middle of a cycle... and now doesn't turn back on.
my dishwasher model is DW80K7050US
Can I have your full model code and serial number via private message?
userjjUGGnj7tM
Hello, Weve also have experienced the same issue.  Model number dw80k5050us.  We have also cycled the breaker, once for 20 minutes, andonce overnight with no success.  Power to the dishwasher has been confirmed. Stopped mid cycle, and now no power, no life on the control panel.  Seems like a common failing panel or control board on many of the others posts.
Hey, we would love to assist you with this. Send us a private message with your serial number so we can look into this. http://bit.ly/2kZXrit
Jakked1
i have the same model just UB (Black) and the exact same issue. powered down from the breaker for over an hour and no success. my washer is 1.5 yrs old and gets ran twice a week. i agree, seems like a common issue from everything i have read. i am a huge samsung advocate and besides the Note 7 issue, ive never had problem. i thought id turn to this samsung forum but havnt seen an resoulutions.
@Anonymous @SamsungBri
userGXNwePrTWM
First time using this, so hoping I'm doing it right. I also have a new Dw80k5050us I  bought from a Sears Outlet, & just installed. Use my old dishwasher, turn off breaker, disconnected the old dishwasher & connected this one. Turned on breaker, nothing.. Disconnect, checked everything & reconnected & still nothing... Help would be Awesome
You will need to make sure that there is voltage to the connections to the dishwasher. If the connections check out, a technician would need to diagnose the problem.
user22iqzhfjWr
Hi. I am currently having the same issue with my 2 year old Samsung dw80k5050us dishwasher. It stopped mid cycle, water has not drained. There are no lights illuminated on the control panel. I have turned breaker for hour, breaker on now and still no power.  Can you help please?  Thank you!
