rojorover
Re: Samsung dishwasher DW80K5050US / does not power on
JUMP TO SOLUTION
 @userLYRMGXdZZu What was the resolution? I'm having a similar issue.
Pinkfitsperfect
JUMP TO SOLUTION
Try unplugging and plugging it back in it should reset itself. If that new you should have a two year warranty at least. Check for rodents, the breaker and the power level. Double check vuse panel n unplug anything that takes alot of power when trying to restart.
userj5dwr3U2R1
JUMP TO SOLUTION
Hi! I have the same issue. What is the solution for this? I have a DW80K5050US. It doesn't power on.
What is the solution?
Thanks!
JUMP TO SOLUTION
Good morning, @userj5dwr3U2R1! Have you tried the troubleshooting here? http://www.samsung.com/us/support/troubleshooting/TSG01001914/
