Samsung dishwasher (dw80r9950ug) lost power
(Topic created on: 9/15/20 5:59 PM)
usersNyjnN8MMl
Kitchen and Family Hub
Our Samsung dw80r9950ug has been running for about 20 minutes when we heard the power off chime by itself. When we went to check on it, it had lost power completely mid-cycle and hot water was pooled in the bottom and dripping off the racks. I tried turning it back on and it seems to have no power at all. I checked the breaker and it hadn't tripped. I turned the breaker off and back on again. Nothing. I checked the outlet and there's no test, but it was still plugged in. I also tried flipping kitchen switches to no avail. Any ideas that might help? It's only about 9 months old. Thanks in advance.
SamsungLarryK
I recommend letting a service technician have a look. Send your full model code and serial number via private message or call
1-800-SAMSUNG directly to get started.
1 Reply
SamsungLarryK
