userDGcwatkKae
Samsung dishwasher stops and delicate light blinks
My dishwasher will stop shortly into the cycle and the delicate light blinks. The hose is not blocked. If I fill the bottom with water then turn it on, it's goes through the whole cycle with no problem. It must be some kind of water sensor that it messing up the cycle. Anyone know what that might be so I can fix it? Any help appreciated!!
6 REPLIES 6
Re: Samsung dishwasher stops and delicate light blinks
Does this occur on all cycles? Is the drain hose clear of debris? Is the unit connected to a garbage disposal?
userDGcwatkKae
Yes, all cycles. The drain hose is clear. Not connected to a disposal. It runs through the entire cycle perfectly if I fill the bottom with water first, but after it finishes the delicate light blinks again. If I don't fill the bottom with water, it stops after a little bit and the delicate light just blinks.
Does the unit have an adequate water supply? Please provide the full model code of the unit.
userDGcwatkKae
I believe so. It was working for about 2 years perfectly and nothing changed. The model is DW80F600UTS. I cant figure out why it works when I put water in the bottom. The cycle seems to go almost all the way. The soap dish opens, it cleans the dishes, but I'm not sure if it goes through the dry cycle. I thought it used to light the 3rd light to say it was done, but the light doesn't seem to come on. In the morning, I only see the lit delicate light on.
Have you tried all of the steps found here: http://www.samsung.com/us/support/troubleshooting/TSG01001922/
userDGcwatkKae
The only possibility is that the hose under the sink got kinked, which I have to check. Got called out of town suddenly sat am because my daughter is in the hospital. I should be back by the end of the week and will check. thanks for your patience. I'll respond again once I can check that
