Samsung electric slide in oven/cooktop
(Topic created: 01-30-2021 11:39 PM)
useregUZM1pbuW
Kitchen and Family Hub
I am writing with sheer disappointment regarding my electric oven/cooktop. The poor design you have manufacturer is going to take a life. The simple brush of the knobs turns on the cook top. After pizza boxes set  ablaze in my kitchen and my son's arm burnt from the flames I am furious with the company's response. You know you produced a major safety risk and your answer is to deny and turn a blind eye. Suggest to customers to get "child proof knobs", which by the way don't fit your knobs properly, is UNACCEPTABLE !!! Your company will pay with the loss of someone's life. I have been a lifelong Samsung customer across the board from cell phones to TV's to appliances. I promise you I am a customer no longer. You need to step up, take responsibility and correct your inadequate and UNSAFE product before someone Dies !
SamsungLarry
Can I have your full model code, serial number, and any ticket number you may have via private message?
1 Reply
SamsungLarry
