Samsung fridge French doors water dispenser
(Topic created on: 5/7/21 7:44 AM)
userM8LxDyhMjF
Kitchen and Family Hub
My Samsung fridge French doors will not stop dispensing water. So once you put your cup in for water, you need an extra cup to catch all the water until it stops. I have tried pulling on the paddle to make it stop,but it doesn’t help. Anyone with this issue and how did you fix it? Thanks
1 Reply
SamsungJam
Does the water lever seem loose at all?  It sounds like it could be an influx of air in the waterline.  Has the water filter been changed at all recently?
