useryzI92hiTqp
Samsung fridge hub calendar
JUMP TO SOLUTION
I cannot get the calendar to come back on the home screen, I wanted to have the 3x3 or 3x6,i removed it by accident and cannot figure out how to add it again. I don't see calendar when I click on apps.
1 SOLUTION
Re: Samsung fridge hub calendar
JUMP TO SOLUTION
We are sorry to hear about this. When you tap the Apps icon, can you swipe left or right to a second page? Does it show up there?
3 REPLIES 3
JUMP TO SOLUTION
useryzI92hiTqp
JUMP TO SOLUTION
Wow, I can't believe I didn't see there was another page! Thank you so much
JUMP TO SOLUTION
You are most welcome.
