Highlighted
Samsung refrigerator leaking water
There water leaking under the vegetable drawers in my French door refrigerator
3 REPLIES 3
Highlighted
Re: Samsung refrigerator leaking water
We are sorry to hear about this. Please send the full model and serial numbers to this PM Link.
Highlighted
Ok can send photos
Highlighted
Refrigerator Model #: RF23HTEDBSR/AA
I have a lot of water leaking under the "cool select pantry" door. (Below the crisper drawers)
I have to soak up the water every few days so it doesnt leak out on the floor.
Also, the ice maker hasn't worked for two years.  It freezes up with iceto the point that I can't get the ice tray out.  I had it services with a new ice maker motor but that did nothing to fix the problem.
I have called several appliance repair places and so far I have found no one willing to work on a Samsung.  I was told to buy a new refrigerator because that would be cheaper than trying to fix this one.
I need advice before I spend another $3,500 on a new refrigerator.
Thanks
