- Mute
2 weeks ago in
Kitchen and Family HubDoes anyone know how to turn the sound off for this dishwasher? The power on, power off and end of cycle melody. I’ve checked the manual and holding the half load and delay start button for 3 seconds results in various different flashing codes, not the rinse aid light. Thanks.
- Mute
2 weeks ago in
Kitchen and Family HubHi! Thank you for reaching out and welcome to our community! From what I can gather of the user manual for your unit, you will need to press both the Delay start button and the Half load button at the same time; while holding those down, press the power button so you can access the setting to acitvate/deactivate the sound ON/OFF function; then press the sanitize button to activate or deactivate the sound ON/OFF function; the Rinse refill light on indicates the sound is on; the Rinse Refill light off indicates the sound is off; to exit when finished, press the power button. (You can check out page 16 in the event you get confused or need to change the setting in the future)
*Support for US products is the focus of this forum. As your device is a non-US model information is severely limited. We kindly suggest that you use this link to look for a support team in the area your product was manufactured in: https://www.samsung.com/visitcountry/
Did you know? Your region more than likely has a community of it's very own!! Check out the following link and join the community in your region: https://r2.community.samsung.com/
