Water Filter
(Topic created on: 1/26/21 8:55 PM)
userBJIVfDOwNL
Kitchen and Family Hub
Which one is the water filter for the model RS27T5200SR?
Maybe it is a new model so there is no information on the filter that needs to be installed?
Thanks in advance.
AftermathLK
When you take the filter out it should have the model on it. Let me know if you can't find it
SamsungBri
Hello, HAF-QIN should be the model code for your unit. You can purchase the filter from your local retailer or by contacting our part distributor, J & J Parts, at 800-627-4368 or visiting samsungparts.com
