Water Leakage Kit for Refrigerator Model RF28FEDTSR/AA
(Topic created on: 2/17/21 8:35 AM)
useruGUX0dCUHS
Kitchen and Family Hub
I bought this model in June 2016. In March 2018, after the warranty expired, the refrigerator began to leak water which pooled and froze under the cool select pantry drawer. In contacting Lowe’s and then Samsung, service was done on the refrigerator to replace the “water leakage repair kit”. The service man indicated this was a very common issue but we still had to pay for the repair! Well, the leaking is back and STILL Samsung refuses to admit there is an underlying issue with the refrigerator. I find it hard to believe that when you spend $1600 on a refrigerator that you should encounter two major issues within 5 years! Anybody have a good solution to the problem?
SamsungLarry
I recommend letting another service technician have a look. Send your full model code and serial number via private message to get started.
SamsungLarry
SamsungLarry
An Accepted Solution has been marked and provided for this thread. The thread will now be locked for further replies. in hopes to keep the integrity of the thread from steering in a non-technical manner. If you have a separate concern, feel free to post again or send one of our moderators a private message with more details. Please note duplicate posts on similar subjects starting 2/1/21, will be removed to keep our community organized and make it easier for our users to find resolutions and needed content. Remember that if you do make a post, please include as many details about your symptoms as possible. Also, make sure that your title is a good summary of the overall situation that's occurring with your product. Thank you for being part of the community!
