Water and Ice panel not working (not shifting from water to ice or crushed ice
(Topic created: 08-08-2021 09:03 PM)
userIhtJxcnAPW
Kitchen and Family Hub
My Family hub refrigerator that was purchased last year all of a sudden facing issue with the water and ice panel. It's not shifting from water to ice or crushed ice. Therefore, I am unable to dispense ice cubes or crushed. I tried restarting (unplug and plug) the refrigerator and no luck so far. Please let me know if you have any solutions that I can try to fix this issue.
MsBri1
Neutron Star
Hello, I am so sorry to hear you are having the same issue with your water and ice panel of the refrigerator. With the troubleshooting steps not resolving the issue, the next suggested step would be to have a technician out to service the product. If you would like to move forward with the process, please send me a private message with your full model and serial number to this link: https://bit.ly/3lVQyQ2
userw2OHuBGFoR
SImilar/possibly related issue here....suddenly the light for Cubed Ice never turns off no matter what mode we're in.  Makes it very difficult to determine what's about to come out!
SamsungJam
At this point the next suggested step would be to have a technician out to service the unit.  If you would like to move forward with that process, please send me a private message with your full model and serial numberhttp://bit.ly/2ihPL97
useruXkiwY8F4o
what ended up being the problem i have the same issue
MsBri1
Neutron Star
userLTMdn8Bdj2
I'm having this same issue.
Was it actually resolved? Can a solution be posted for everyone to see so we can fix our refrigerators without having to call a tech out?
