Water and ice output mixed up
(Topic created on: 4/19/21 2:03 AM)
userPZV57Sd6H2
Kitchen and Family Hub
Hi,
my side by side fridge works perfect since years, but now I have a problem with the ice maker. The output is mixed up, that means if I press ice I'll get water on the water output. If I choose water ice blocks where prepared to come out (I can hear it). But they can't get out, because the flap is closed. Then I have to press ice again to open the flap to get my ice blocks.
I've taken away electricity for a while, but that doesn't help.
Any idea what to do?
Thanks for any hint.
Robert
hottie4u
Give it back to ur guy friend
SamsungLarry
It sounds like something was put on backward during installation. I recommend reaching out to the person that installed the unit in your home.
