Water dispenser light
(Topic created: 02-24-2024 02:43 PM)
Idgie27
Kitchen and Family Hub
Hi
Does anyone know whether model
RS68A884CB1 fridge has a light in the water dispenser?
thanks
gemma
GaryB82
Epic Samsung Care Ambassador
If you already own the Refrigerator I would suggest looking to see if it has the light in the picture below this is from a different model but should be kinda the same 1708816674476.jpg
If you've found my post to be helpful, Please like the post.
If my response resolved your issue, please press the Like and ✓ to Accept as Solution button.
1 Reply
GaryB82
