Highlighted
Water dripping from door ice dispenser from Ice maker - Model RF25HMEDBSG/AA
I see many have had issued with the Samsung French Door refridge's ice maker.  Mine is just 2 years old and about 4 months ago i noticed that when getting ice, a small amount of water that is building in the dispenser area comes out first, then the ice proceeds to come out.  When I took out the ice box to see if there was an issue, this was alot of frost in the ice box/ice maker.  With the water coming out of the dispenser area, it builds up the water catch area and then ultimiately down the front.  Then I am having to clean it daily.
I have seen many fixes listed...from making the fridge not level to siliconing areas in the ice box area. Does anyone know if any of these fixes actually worked or if there is another solution that does.  It just seems odd that a $3k+ fridge has this issue.  I see there is some class action lawsuit, but I am just interested in trying to the stop dripping so I don't have to clean it every day.  Other than that, the ice maker works fine.
Any thoughts or fixes would be greatly appreciated.
2 REPLIES 2
Highlighted
Re: Water dripping from door ice dispenser from Ice maker - Model RF25HMEDBSG/AA
We are sorry to hear about this. Please send the serial number to this PM Link.
Highlighted
This was the first thing I noticed before my ice maker froze over completely. Hope yours doesn't end up like mine but if it does the short answer is the only fix is to shut your ice maker off for a few weeks to defrost and then turn back on and it will work until it starts doing it again and then repeat defrost again.
