Cannot reset fridge water filter indicator
(Topic created: 04-26-2021 11:18 AM)
user9PVM9M7dIb
Kitchen and Family Hub
Hello,
I can not reset the water filter indicator of my fridge RF261BEAESR/AA. I pressed the fridge & power cool buttons for 3 seconds but did not work. I pressed the ice off button for 3 seconds but did not work. The indicator still blinking red light. Is there a solution? Thank you
MrLarry
Neutron Star
Hey, give this link a shot: https://www.samsung.com/us/support/answer/ANS00060149/ If this does not help I recommend letting a service technician have a look. As we would like to gather additional information and look at this from a case-by-case basis please provide the full model code and the serial number of the device as well as your best contact phone number, name, and email.
Send a message on Facebook
Send Message on Twitte
Send Message to Moderator
Not applicable
I am sorry to hear about this. Do any of the buttons work on the refrigerator?
user9PVM9M7dIb
All buttons are working but filter indicator light still on.
MrLarry
Neutron Star
