Highlighted
Water leak
JUMP TO SOLUTION
I have a Samsung RF28HFEDTWW/AA Refrigerator with top and bottom ice makers. I have started seeing water in, and under the Pantry drawer. I see no visible leaks. I pulled the top ice maker out and it was frosted over. I removed the frost, and put it back in. A couple days later the water is back in the pantry. I noticed that there is a filter or something at the back of the pantry drawer, and if water came from it the water would probably go into the pantry drawer. What is the purpose of this filter? What could be causing the problem?
1 SOLUTION
Highlighted
Re: Water leak
JUMP TO SOLUTION
Hey, give this link a shot: https://www.samsung.com/us/support/troubleshooting/TSG01001852/ If this does not help I recommend letting a service technician have a look. Send your full model code and serial number via private message to get started.
1 REPLY 1
Highlighted
Re: Water leak
JUMP TO SOLUTION
