- Mute
- Email to a Friend
10-11-2020 03:58 PM in
Kitchen and Family HubMy samsung dishwasher dw80k7050us started toggling power on and off by itself. After maybe 20 minutes, it stopped. It started again toggling. And now it's stopped and I can't power it on. Any thought of what is going on?!
Solved! Go to Solution.
- Mute
- Email to a Friend
10-11-2020 08:32 PM in
Kitchen and Family HubTry the troubleshooting steps :)
If your dishwasher turns on with the Power button, but won't start when you touch Start, see our article for Dishwasher doesn't start or fill with water.
Touch Power on the dishwasher.
The dishwasher has a Power button that has to be pressed before a cycle can be selected or started. Also, if your hands are wet or soapy, it may not recognize that it has been touched. Make sure your hands are dry when you touch the buttons on the control panel.
The Power button should be clean as well. If it's dirty or covered in grime, gently wipe it clean with a soft damp cloth, and try again.
Check the circuit breaker.
Check the circuit breaker for any tripped circuits. If you see one, flip the circuit all the way off and back on again. If it continues to trip, contact an electrician to diagnose the issue.
Check the switch near the dishwasher.
Most newer homes have a switch (like a light switch) on the wall in the kitchen near the dishwasher. This switch turns the power on and off for the dishwasher. If your home has this switch, verify it is in the on position.
Request service.
If the dishwasher still doesn't turn on, visit the Support Center to request service or send a private message to any of the moderators with your full model and serial number :)
- Mute
- Email to a Friend
Request service.
- Mute
- Email to a Friend
10-12-2020 06:01 AM in
Kitchen and Family HubThe Power is still turning on/off by itself just like the button is stucked. Unable to push any other button. dw80k7050us/ac 02. The control panel is dry and clean and my hand too. Breaker is ok. No other switch.
Note: After few minutes of toggling, it shuts down for a while and I'm unable to power it on manually. I'm also hearing a kind of "click" when it toggles...
