Highlighted
ice maker not working after filter replacement
Hi. I have a Samsung side-by-side refrigerator/freezer. The model number is: RSG257AARS. After replacing the water filter, no ice! Here's what I've tried so far:
1) Checked to make sure the ice maker is indeed "on."
2) Water pressure: it's good.
3) Hit the reset button. It chimed, made 7 tiny ice cubes, and then stopped.
4) Turned off the power for 5 minutes. After, I tried the reset button. Now it will NOT chime. There is no sound at all.
This same exact problem happened the last time I changed filters, and I tried the hair dryer method and so many things, I don't know what I did to fix it. I've gone all through the similar posts here, but I don't see an actual solution. Any thoughts? Has anyone fixed this issue?
