Highlighted
re: refrigerator freezing inside
i see in this community that this is an ongoing issue with this side by side refrigerator.ice continues to form on the back wall as well as under the deli draw! everything is set properly and the problem persists!
i cannot afford to keep having service people in to install some small clip that doesnt work! samsung is well aware of this problem and does nothing to help. any suggestions they have given have not resolved the problem.
4 REPLIES 4
Highlighted
Product Expert
Re: re: refrigerator freezing inside
Hi @userS8qH66dMJj ,
If the coils on your fridge are dirty or dusty, then the compressor needs to work harder and longer.
The cold air in your refrigerator comes from the evaporative coils located behind the freezer compartment. ... If your refrigerator is freezing food and you even have vegetables freezing in refrigerator drawers, any of these parts could be the source of then problem with a refrigerator freezing food.
  • 1 The Thermostat Has Been Set Too High. This happens quite often
  • 2 The Coils are Dirty
  • 3 A Leaky Gasket
  • 4 A Faulty Thermostat
  • 5 A Problem in the Damper
If you've found my post to be helpful, please like the post. If my response resolved your issue, please press the "✓ Accept as Solution" button.
Highlighted
i have tried everything suggested
Highlighted
the food is not freezing. its water under the deli drawer on on the back wall. its been serviced 3 times already
Highlighted
We are sorry to hear about this. Please send the model and serial numbers to this PM Link.
