10-20-2020 05:20 PM
Can't seem to find my previous post. I was wrong about the model. It is a Samsung RS2530BWP. I found an article that suggested pressing the Power Freeze and Freeze buttons at the same time. Below the temperature select for the freezer, a circle with a line through it appeared. I could hear something happening but nothing seemed colder. Waited almost 40 minutes, then pressed the two buttons and held them for 3-5 seconds. I think I hear the compressor now.
Is this the best way to reset it?
This happened suddenly. Noticed a few days ago that the frozen food on the door seemed soft. Then yesterday, nothing. Been scrambling to find a solution short of a new one.
10-20-2020 06:32 PM
This issue will require a service technician to determine the cause of the refrigerator not cooling. As it is so far out of the warranty, you can locate an authorized service center at the following link. https://www.samsung.com/us/support/service/locations/
10-23-2020 03:19 AM
Absolutely not worth it. I am looking at at least $150 to get someone to look at it, $3-400 for a compressor, the likely problem, plus labor to install it. And it is 10 years old, if that. I am very disappointed.
