- Mute
09-27-2023 10:46 AM (Last edited 09-27-2023 11:39 AM by SamsungAllie ) in
KitchenMy bespoke frig door alarm was working fine for the first few months then just stopped working when the frig or freezer door is opened. I have already tried holding down the door alarm button for 3 seconds and that doesn’t change anything. It is model code name rf29bb86004maa
Solved! Go to Solution.
- Mute
09-27-2023 11:55 AM in
KitchenWith you already doing the required troubleshooting for this, we recommend having the fridge serviced. Please send a private message to any of the mods here with the fridge's full serial number so that we can get this started for you.
- Mute
