Family hub leaking water as ice is melting (RS68N8941SL)
(Topic created: 01-12-2026 08:28 AM)
crdrummond
Kitchen
Hi - I have a family hub RS68N8941SL.  I'm based in the UK and have posted in the EU community but so far no responses so trying here...
The hub is currently dripping water from the base which is coming from the ice maker. Itโ€™s making ice but then melting and dripping out of the bottom of the bucketโ€ฆ
The main freezer is -19 degrees so I think there might be an ice maker fan which may need replacing.
(note I have previously successfully replaced the main evaporator fan when the whole freezer section stopped freezing a year or so ago, but I donโ€™t think thatโ€™s the problem here - but I could be wrong)
From some research I believe if there is one, that it is behind the ice maker itself, but I cannot for the life of me remove it.
Iโ€™ve unscrewed the screws and tried to put a flathead screwdriver where the little arrow is on the right-hand side to release what should be a catch holding the ice maker in place. However there appears to be nothing there - so all Iโ€™ve achieved is scratching / bending the plastic around the arrow.
Please could someone provide to help or guidance; Iโ€™ve seen the eSpares video, but I just cannot get the thing off!
Any thoughts gratefully received!
1 Reply
Samsung_Moderator
Kitchen
Thanks for reaching out. Support for US products is the focus of this forum. As your device is a non-US model information is severely limited. We kindly suggest that you use this link to look for a support team in the area your product was manufactured in: https://www.samsung.com/uk/support/
*We do not offer self repair advice here as any type of self repair can void any warranties or accommodations that would otherwise be available to you
