Ice Lock icon needs to go off on 3 door refrigerator
(Topic created: 07-25-2024 08:46 AM)
vpartin1
Kitchen
Ice Lock icon needs to go off on 3 door refrigerator.  I am getting frustrated.  RFG297HDRS model
realaud
Honored Contributor
Kitchen
You have to press and hold the ice off control button for a second, till you hear the chime and the light goes off. In any case, the ice "lock" does not lock the ice maker, it turns off the water supply to the ice maker and the function to make ice.  If there is already ice in the bucket, you will still be able to get it.  If you are not getting ice, it's because the supply of ice has been depleted.
Please mark any response that helped you as your solution.
Noobie
Comet
Kitchen
Then don't use it.
vpartin1
Kitchen
As long as the ice lock is on, I am unable to get ice.
Noobie
Comet
Kitchen
So you want to unlock it?
vpartin1
Kitchen
Yes
Noobie
Comet
Kitchen
vpartin1
Kitchen
Not my type of refrigerator.  Here is mine
 Here is mine.  3 door, not 4.
realaud
Honored Contributor
Kitchen
realaud
Honored Contributor
Kitchen
To be clear, the ice off button is where the writing is, not the lit up icon.
Noobie
Comet
Kitchen
bru I literally said that.
