Samsung BESPOKE Jet Vacuum Accessory Cradle - need Power adapter info
(Topic created: 10-22-2023 07:45 PM)
Nyquist-Shannon
Kitchen
Hey all, I just bought a Jet AI vacuum and have found out the accessory cradle does not ship/no longer in production. Ive found a NOS one but now I need to find the proper AC charger that plugs into the accessory stand to charge the battery when its in the battery slot on the accessory stand. Can someone here help me with this info? if anyone has one and has the specifications on  which AC charger to get, i can find one from amazon, etc. thank you!  I attached some images from a youtube video to show the part im referring to. this is not me in the video nor is it my video.  My Everyday Tech - Who is this for Samsung BESPOKE Jet cordless vacuum cleaner [4LDlU7Dfe6g - 1115x627 - 3m50s].pngMy Everyday Tech - Who is this for Samsung BESPOKE Jet cordless vacuum cleaner [4LDlU7Dfe6g - 1115x627 - 3m56s].pngMy Everyday Tech - Who is this for Samsung BESPOKE Jet cordless vacuum cleaner [4LDlU7Dfe6g - 1115x627 - 4m00s].png
Kitchen
I found a NOS charger on fleabay from Australia. Hopefully you can see the specs. I'm not able to use this charger because the new battery for the AI vacuum won't fit in the cradle. I still use the cradle for the accessories though so it all worked out. 20240119_202225_1000018214_1705724545.jpg
CHOTAS
Kitchen
What is an NOS one?
Kitchen
New Old Stock.
Anyway I figured out the answer elsewhere.
usernRVEsJ8kx9
Kitchen
Can't believe they discontinued the cradle... for the retail price of the AI (I thankfully paid less than half) it should definitely come with it. Even a simple one without a battery charger.
I got mine coming from the UK in a couple weeks but I am curious... what adapter did you buy in case I ever want to use the charger?
V1135
Kitchen
Where did you find the cradle?
Kitchen
From an Australian seller on fleabay
usernRVEsJ8kx9
Kitchen
I got mine on ebay as well, from a seller in the UK. I massively overpaid for it and as Cinematographer states the battery cradle doesn't fit the AI battery, but I was sick of having the tools on the floor or in the closet. The way my seller packaged it, it could totally fit in the vacuum's box with ease and Samsung sucks so much for not including it with such an expensive appliance.
I love the vacuum though.
Kitchen
Agree with these points as well. I think I paid top dollar for this item too. Way overpriced. And yes the vacuum is totally worth it. I left dyson for it. Longer battery, more suction power, super easy to clean and the app is helpful as well.
Kitchen
usernRVEsJ8kx9
Kitchen
Thanks for the quick reply. If the AI battery will not fit, will be pointless to buy the adapter to me then. My main use will be for accessory storage anyway... which again... should have been included in their top-of-the-line product. But I digress.
Thanks again!
