Samsung Side by Side Refrigerator RH22H9010SR bottom drawer/bin removal
(Topic created: 11-05-2024 09:36 AM)
RWReiterJr
Kitchen
How can I remove the bottom drawer/bin (in the refrigerator side) of my Samsung Side by Side Refrigerator RH22H9010SR, in order to thoroughly clean the drawer/bin as well as under and behind it?  After I remove the "middle" drawer /bin (directly above the bottom drawer/bin), there is a plastic shelf/ separator above the bottom drawer, with a clear plastic drawer/bin "cover/door" attached via hinges to the shelf/separator.  I can't seem to figure out how to release whatever tabs/catches are keeping that shelf/separator from sliding out horizontally.
GaryB82
Galactic Samsung Care Ambassador
Kitchen
Hopefully this picture helps from page 37 of the user manual this is the only information I can find but will keep looking
If you've found my post to be helpful, Please like my Comments โœ“โœ“โœ“.
If my response resolved your issue, please press the Like and โœ“โœ“โœ“ to Accept as Solution button.
1 Reply
GaryB82
Kitchen
