Samsung rf28r7201sr/aa water dispenser light
(Topic created: 04-07-2025 04:15 AM)
ragdolls
Kitchen
I just purchased this Samsung rf28r7201sr/aa and I can't seem to get the
water dispenser light to work,  there is a small bulb. But nothing I've tried
has worked!  Any ideas?
Samsung_Moderator
Kitchen
Hello! Thank you for reaching out! From looking at this further from the user manual, it seems there is no dispenser light. I would also recommend looking at your user manual using the link below.
https://downloadcenter.samsung.com/content/UM/202105/20210525161422514/FDR_AW3-14_FL_DA68-03833A-05_...
Samsung_Moderator
Kitchen
userZlCwWl8vC3
Kitchen
There looks like there is a light there or at least a spot for one. Is there a light kit that can be added. It seems so silly to spend $2500 for a fridge and not have a dispenser light
Samsung_Moderator
Kitchen
Hello! Unfortunately, no, there is not one made that can be added to a fridge without it.
