phil9
- Mute
12-18-2025
11:45 AM
(Last edited
12-19-2025
08:18 AM
by
SamsungStephani
Hi, I have a Samsung Model NQ70M777ODG wall oven combo and the problem is the microwave will only heat up the food when it is set to 50% or less power. Everything else works fine. Not sure if I should start with the main control board or the magnetron (which tested fine on the ohm test) The oven is only 3 years old and the upper oven was not used much at all.
Thank you
