Audio out on TU8000's RCA jacks
(Topic created: 11-11-2025 04:27 AM)
dlpg47
Cosmic Ray
LED and OLED TVs
Is audio always available via the rear panel audio jacks and if not can it be enabled regardless of how audio is setup otherwise? My "normal" audio out from the TV to home receiver is via HDMI and that seems to disable audio at the RCA jacks and optical rear panel connections.
Reason I'm asking this is that I have a hearing aid device that can connect to either RCA jack or optical cable to a TV that allows me to "hear" the audio from the TV directly to the hearing aids while "normal" audio can be heard by others in the room.
This works OK on another TV in the house but not the Samsung TU8000.
Pianodude58
Honored Contributor
LED and OLED TVs
The RCA jacks on the Samsung TU8000 are input jacks for connecting older devices. They are labeled as "Component/AV IN" and are used for video (yellow, blue, red) and audio (white, red) signals from sources like VCRs or older game consoles.
Pianodude58
Honored Contributor
LED and OLED TVs
dlpg47
Cosmic Ray
LED and OLED TVs
Ah.... so its INPUT, not OUTPUT for Component/AV, that explains it. Should have moved the TV away from the wall to read the label or read the manual.
Now next to component is an optical output connector. When I connect a cable there, it shuts off audio via the HDMI cable I have connected to home theater receiver. Is there are way I can have both connections active for audio in settings somewhere?
Thanks for your help.
Pianodude58
Honored Contributor
LED and OLED TVs
The Samsung TU8000 cannot output audio to both an HDMI and an optical port at the same time; you can only use one output at a time. You will need to choose one connection in the TV's sound settings to enable the audio output.
dlpg47
Cosmic Ray
LED and OLED TVs
I kinda thought that was the case, unfortunately, just wanted to make sure I wasn't overlooking something in the TU8000 settings.
Thanks again for your help.
